Code Provision
Code Provision
Somehow I cannot find the code provision which requires that rebar in earth retention structure cannot touch the building foundation. There is some type of minimum spacing between tension rods and concrete footing. Help much appreciated.
RE: Code Provision
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
RE: Code Provision
RE: Code Provision
As other said, if you are looking to connect a building foundation and an accessory retaining wall, you do have to account for the forces involved.
