Anybody Knows How to Select API Material Class?
Hi.
I Want to choose an API material Class for centrifugal pumps with following characteristics:
Service: Gas Condensate
Min Operating Temperature: -79
Chloride Concentration: 65000 ppm
H2S Concentration: 37000 ppm
Capacity: for 2 Case: 1) 10 m3/hr 2) 100 m3/hr
Continuous operation
RE: Anybody Knows How to Select API Material Class?
Nobody knows?
water content?
water content about 15%
Do you intend buying a pump, if so, why not give the spec to the pump supplier and let them make their recommendations?
yes i am a client, but i know about the procedure for finding a coorect way to the pump vendors use. Can you help me?
They will know from previous experience or they will consult the corrosion tables and like data that they will probably have.
You can also source this info'. from the internet - a good learning experience for you, "google is your friend".
