automatic decontamination
please i want to know how the automatic decontamination in the machine AMADA fo 3015 (Fanuc Series 160i-l)
RE: automatic decontamination
what is this automatic decontamination you speak of?
from Google, I see references to coatings removal and such.
also scarier things, like decontaminating surfaces that have radioactive contamination.
Do you want to do that with your machine?
Jay Maechtlen
http://www.laserpubs.com/techcomm
How clean or nasty is the environment where the gas bottle is?
Could you be getting contamination into the regulator when you make the change?
(what kind of chemicals could be in the area, or in the air?
Is the new bottle nice and clean when you connect it up?
Have you asked Amada about this? Do others in your area have good success with that gas supplier?
Jay Maechtlen
Maybe your calibration time is set too high; check parameter 15205 (calibration time in seconds; usually from 180 to 300 depending on resonator type).
the machine parameter 15204= 1346 and it is not stable in each reset ...
Other than that, next, it could be the power sensor that is bad, or your internal optics are due for a replacement. How many hours do you have on the internal optics?
