Incremental Volume of a Cone Calculator
Trying to write a formula in excel that will calculate the incremental volume of a cone inch by inch. The diameter of the top of the cone is 34' and the height is 18.75'. Total volume is 5674.50 cuft but I can't figure out how to write the formula so I can generate the volume as I move down the height of the cone. This is generating the volume of solids in the cone. Maybe it is because it is Monday, but I can't figure this out. Thanks.
RE: Incremental Volume of a Cone Calculator
I don't think you are exactly right. The volume of the cone's frustrum will be slightly larger than your approach predicts, because the volume of a cone is proportional to the cube of the height rather than to the square of the height.
A quick bit of algebra suggests that your approach underestimates the frustrum's volume by
pi * (tan(t))^2 * (delta H)^3 / 12
where t is the semi-angle at the cone's apex, and
"delta H" is the thickness of the frustrum.
Based on the given volume, base diameter and height, the minor radius is zero, so this is not a frustum, but a true cone.
