Magnetic field,
Magnetic field,
Good morning,I have a question reffering to magnetic field (B):
Considering an cylindrical magnet (dipole) in plane (resulting an rectangle). If magnetic field can be determinate analithic (aproximate) in vertical axe (axial), how can be determinate analithic magnetic field tangential based on angle between vertical axe and horizontal axe.
If somebody can help me with some sugestions or links, or idees I will waiting your answare.
Thanks in advance for advice to all.
Best regards.
Mess with the best die like the rest...ANSYS is the best !!!
RE: Magnetic field,
I suppose what you are looking for is here
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
