NX6... Trim curve to solid edge internal errors?
Every so often I get in a hurry and accidentally select the edge of a component body to trim a curve. NX6 does not like this at times and will error followed by Undo Successful (if you're lucky). Much safer to trim curves to curves. That said, in later versions can one safely trim curves to component edges? And no, my employer is not on maintenance at this time (sic).
Bill
Bill
RE: NX6... Trim curve to solid edge internal errors?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
So , yes, you should be able use an edge to trim to.
Tomas
