Adding a counter to a macro
Adding a counter to a macro is a easy way to find out how useful
your macro is to others. You can even put in hidden comments like
owing you a coffee after so many uses.
I also like to be able to find out what users use it.
Can you tell me how to get the users id name.
Dim path As String
Dim filename As String
Dim scrpt As String
Dim objFSO, objReadFile, contents
Dim ccontents As String
On Error Resume Next
path = "c:\temp\" 'location of file
filename = "test.txt" 'add text name
scrpt = "test" 'name of macro
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objReadFile = objFSO.OpenTextFile(path & filename, 1, False)
ccontents = objReadFile.ReadAll
If ccontents = "" Then
ccontents = 0
End If
ccontents = ccontents + 1
mut = Round(ccontents / 25)
If ccontents = 100 Then
MsgBox "You have use " & scrpt & " " & ccontents & "times you must really like this program."
ElseIf ccontents = 1 Then
MsgBox "Thank you for trying " & scrpt & " I hope you enjoy this program."
ElseIf ccontents = 25 * mut Then
MsgBox "You have use " & scrpt & " " & ccontents & "times. I think you owe me a coffee"
End If
Set Datos = CATIA.fileSystem.CreateFile(path & filename, True)
Set ostream = Datos.OpenAsTextStream("ForAppending")
ostream.Write ccontents & Chr(10)
ostream.Close
RE: Adding a counter to a macro
You can get few additional data using Set objNet = CreateObject("WScript.NetWork") . Bellow is just an example how it can be used, I'm sure you can adapt code to your needs.
' Purpose: CATScript will create Date, Time and User parameters in an active CATPart
' Usage: 1 - A CATPart must be active
' 2 - Run macro
' Author: ferdo (Disclaimer: You use this code at your own risk)
Sub CATMain()
Dim oParams As Parameters
Set oParams = CATIA.ActiveDocument.Part.Parameters
oParams.CreateString "Date",Day(Date)&"/"&Month(Date)&"/"&Year(Date)
oParams.CreateString "Time",Time
oParams.CreateString "User", objNet.UserName
End Sub
or (just another example)
Sub CATMain()
Dim objNet
MsgBox objNet.UserName ' User
MsgBox objNet.UserDomain 'Domain
MsgBox objNet.ComputerName 'Computer
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208
Thanks ferdo thats what I was looking for.
