Blocks, Need Help
Blocks, Need Help
I need basic help with block.
I build a block in block editor.
I close the block editor and insert it in the main model space
The block works with the MOVE command but doesn't work with STRETCH command.
Any Solution?
I used to build block which could work with both MOVE & STRETCH commands
Please help
Sincerely,
Fayaz
Any Solution?
Please help
Sincerely,
Fayaz
RE: Blocks, Need Help
2. Insert your block into the main drawing.
3. Run the BEDIT command, OR select the block and right-click and select Edit In Place from the pop-up menu. Depending on your version of AutoCAD, choose to edit the block internally to the drawing, or "Edit in Place". Make any necessary changes, including your stretch. Now when you're done with any changes in the block, make sure you have no entities selected, right-click, and choose "Close Block Editor" from the pop-up menu. Elect to SAVE Changes. You're done !
Chicopee is right - you can't stretch a "hard" block - one that's inserted into a drawing but not exploded. But you can get what you were wanting by editing the block " In Place ".
Ok -give this a try and let us know how it worked !
Good luck -
Charley.
Dynamic blocks are available in later versions of CAD and they can be created with the block editor. Some of the parameters allow stretching the block in a predefined manner. For instance, you can create a 3 dimensional representation of a standard 2x4 board. Using the dynamic blocks options you can add a grip to one end of the board which could allow you to stretch it to standard dimensions of 4' 6' 8' etc. where it would snap to those predefined options, not stopping between. Alternately you can set it to stretch with the cursor to any dimension. It just depends on what you want it to do.
For instance, our company has one for parking spaces (Civil firm) where we can select the depth of the stall at fixed dimensions (18, 19, or 20 feet), the width at fixed dimensions (8, 9, or 10 feet) and the number of spaces by dragging different grips of the dynamic block. This block also allows single or double stacked (face to face) stalls. It is slightly faster that drawing one and offsetting it hundreds of times to lay out parking lots.
Your second option would be to use the SCALE command and scale the block in the x, y, or z direction only, by the amount you want.
At the command line enter SCALE, select the base point, enter "1,2,1" to scale by 2 in the y direction only. Alternately, select the block, invoke the PROPERTIES, and adjust the x,y,z scale of the block (scales from the insertion point).
Having dynamic blocks lets you have multiple instances of the one block with different lengths, rotations, etc. Editing the block definition of a standard block will change all instances of that block in the drawing (not always what you want to do).
Nate the Great
www.ceieng.com
There are free classes here from prior years that explain how to create
http://au.autodesk.com
