Efficiency of condensing water heater VS cupronickle fin type w/ mixing valve
So I'm trying to choose the proper water heater for our application and make sure I'm not being taken in by boiler salesmen trying to sell me a condensing boiler...
My question is pretty simple...Will a standard cupronickle fin sealed combustion boiler (looking at an RBI Dominator) with a mixing valve to maintain higher inlet temperatures be a long-lasting substitute for a condensing boiler? Our current water heater has run without a mixing valve, and was of the copper-fin, non-sealed combustion type, and has twice had an extremely corroded heat exchanger replaced.
Our system is 100% makeup, once through process. Makeup water replenishes the 500 gallon storage tank which we set at 140 degrees. We use 1000-2000 gallons per hour. I'm looking at a 2MBH unit which should be more than enough.
Would the efficiency losses be negligable if we used a mixing valve to bring inlet temp up to 150 degrees or so to minimize condensation?
Thanks for the advice guys. Let me know if more information is needed.
RE: Efficiency of condensing water heater VS cupronickle fin type w/ mixing valve
Generally speaking 95% of the cost of a boiler over its lifetime is in fuel. you can quickly calculate the fuel savings based on run-time (full fire equivalent), efficiency and gas cost to see if it makes sense financially.
Caveat: I'm a condensing boiler salesman.
Sean
Sean
Is 120 too low to try using a bypass or mixing valve to keep inlet temp up high enough for a non-condensing model?
You said the inlet water to the boiler was 100% makeup. To me that implies cold water, not 120F water.
If your make-up water is 120F and you only want 2000 GPH your boiler at 2,000,000 btu boiler is grossly oversized. At 100 degree delta T our 1.5 Million condensing boiler can supply you with 1812 GPH. I dare say most other mfg's should be similar.
Double check your parameters and size according to the load rather than the old boiler.
Sean
I might have used the terminology wrong. The water used in our process never returns, and the makeup water feeds into the 500 gallon storage tank. Delta T is about 90 degrees for our 1-2000 GPH, but there may be spikes in usage.
I think if I decide to go with a condensing boiler however, makeup water would not be piped into the storage tank, but rather into the boiler intake before the bypass valve....at least that is what I have seen in plumbing drawings.
Based on your delta T of 90 degrees We would quote you a 1.5 million btu boiler which would give you 2016 GPH. I'm sure other manufacturers would be similar.
Our 2 million would give you 2688 GPH, hugely over sized based on your post.
Sean
