Metal for ultra low sulfur in oxygen process stream
I need some help on selecting the metallurgy of sample tubing for an oxygen stream with extremely low sulfur concentrations, 1~2 ppb. The metal needs to be something that will not absorb the sulfur so that we can analyze the process stream. Even a few ppb of sulfur can damage the catalyst that we are running in the system.
RE: Metal for ultra low sulfur in oxygen process stream
I assume that won't work, because your temperature is too high (you mentioned a catalyst). Maybe you would like to tell us the temperature and expected gas composition so we can give you a better guess?
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
