open files SE ST4 in NX7.5
I have some problems with NX7.5:
Is it possible to open files from SE ST4 in NX7.5?
I can open files from an earlier version but not these.
Is it also possible to load an SE assembly and get results in NX7.5?
I can make boundary conditions but get 'result is in wrong format' when solving.
(when I use SE .par, everything works fine)
Also my CAST opens but I only get the table of contents, no tutorials, he keeps saying 'loading'...
Thanks for helping!
Joris
RE: open files SE ST4 in NX7.5
My guess is you have incompatible Parasoid release versions between NX and SE.
Check the version of Parasolid in each program. You cannot open a newer version file in an older version.
Ben Loosli
Thanks Looslib!
But do you know how to ged a result from a loaded SE assembly in NX?
Thanks!
SE ST4 files can be opened in NX 7.5.5 and 8.0.
Mark Rief
Product Manager
Siemens PLM
OK, thanks. Now I have the files in .stp, it is possible to open these but I have every time the same problem when I want to see the result, error: 'result is in wrong format'. I tried the solution from SORT1 (see other topic in this forum) but it still doesn't work..
Can anybody give me some advise please?
Or does anyone know where I can get 1 to 1 conversations online to help me with some specific problems? I'm losing a lot of time in searching for the same solution again and again.
THANKS!
