PTC (Solid State Motor Control)
I came across the following Spec requirement for solid state motor control: The SSMC shall be capable of the following: Accuracy - Zero sequence CT with PTC
What does this mean? What is its significance?
RE: PTC (Solid State Motor Control)
PTC is Positive Temperature Coefficient, a type of thermistor whose resistance increases rapidly with rising temperature. Good for motor protection. See attached.
Zero sequence CT is used for ground fault protection.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
