Parametric Sweep - Component Array
Apologies in advance, I'm sure this has been asked before, I just can't find the right combination of keywords to find a post about it.
I have a small rectangular shape inside a larger one, and I have rib-like components in a linear pattern on each edge spanning the distance between them. For the corners, I'd like to have the lengths of the ribs parametrically reach out to interface with the wall (at given angular increments) without having to make a hundred different part lengths and arrange them meticulously inside. I can add just about any features to both the inside/outside rectangles to make this happen, but any feature-driven pattern just gives me a linear array, not a sweep.
Right now, I've got an oversized part, and I'm using a cut-extrude in the assembly to trim it off. Is there a more elegant way to do this that I'm missing? (Illustration attached, please excuse my Paint-fu.)
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems." -Scott Adams
RE: Parametric Sweep - Component Array
Just to clarify, the parts themselves are gentle arcs (swept boss). If they were straight spars, I'd do an extrude-up-to-face and use the outer rectangle to terminate, but I can't really think of a way to extrude a swept profile up to a face besides what I'm doing right now.
Try using Weldments. you can setup the profile of the rib as a weldment profile & then extrude the ribs within a single 3D sketch. weldments do an excelent job with merging corners to your specifications
