Pressure Relief Valve Discharge Pipe Sizing
I could use some guidance on sizing relief valve discharge pipes. I have an industrial waste water treatment plant that has 2 filter banks for final polishing of treated water before it is discharged. One bank treats 6,700 GPM and the other 3,300 GPM. The main influent lines have relief valves on them. The larger bank has a 10"x8" valve and the smaller has a 6"x8" valve.
Right now, the relief valve discharge lines just go a few feet out the wall and turn down to the ground. I have been asked to route the lines to a more suitable location for discharge, which is about 250' away. The friction losses and velocities in 10" pipe carrying 6,700 GPM and 8" pipe carrying 3,300 GPM are very large.
So, what is the proper way to size these lines? Is there a target velocity or friction loss I should shoot for? Also, can I combine the 2 into a single discharge header?
Thanks for your help
RE: Pressure Relief Valve Discharge Pipe Sizing
Water PSV's are not critical flow devices so they are not quite as touchy about downstream pressure as a gas PSV is. For that kind of problem you have to account for elevation changes (for discharge higher than inlet I use the hydrostatic head as my tail pressure, if the discharge is lower than the inlet then I ignore the elevation change), then I like to use a head pressure of about half of PSV set point and a tail pressure determined by elevation. Adjust pipe size until the head and tail pressures are in the ballpark. If you combine the two PSV into one line then use the combined flow for your pressure drop calculation. Darcy-Weisbach is probably your best bet for flow calcs.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
