How to select item within a selection
New to forum and vba coding,
I am trying to move through a search result collection, select each one then perform measure inertia.
Have managed to get search results, but stuck on how to select each in turn to so that I can analyse
Sub CATMain()
Dim productDocument1 As ProductDocument
Set productDocument1 = CATIA.ActiveDocument
Dim part2 As Object
Dim selection1 As Selection
Set selection1 = productDocument1.Selection
Set selection2 = productDocument1.Selection
selection1.Search "Name=partbody,all"
node_amount = selection1.Count
For node_count = 1 To node_amount
' selection1.Item(node_count)
' how to move through each of the found items in the search to enable measure inertia command????
CATIA.StartCommand ("Measure Inertia")
Next node_count
End Sub
Any help appreciated.
RE: How to select item within a selection
Thanks Fernando,
But when I click the link, there is no file.
OK, I'm talking about CATIA Portable Script Center, you can search it with Google, I'm sure you can find it. If not, let me know so I will post a link to my DropBox....
Fernando
https://picasaweb.google.com/102257836106335725208
Thanks Fernando,
Got the file, looks like some reading required !!!
