Update Modified Transforms Toggle. NX7.5
I was having an issue in Drafting when creating a drawing from an assembly. All of my parts were shifting on the creatiion of the drawing. Anyways I called GTAC and they had me turn this Update Modified Transforms switch off. Under help it has a small discription of what this swtich does. I still do not understand. Does anybody else have experience with this switch and what it is used for?
RE: Update Modified Transforms Toggle. NX7.5
Then The Update modified transforms is on/off if you would like to "pass" that transformation into the NX Assembly or not.
I.e allow the components to move accordingly in NX.
I sometimes see "similar" things happening, Messages that component transformation was attempted but not successful due to assembly constraints. I have not been able to track down the reason for this yet. I am pretty convinced that nobody has moved anything in the structure editor.
Tomas
