doors and windows
doors and windows
I am trying to create a door openings but the dimension I am getting with the door is in inches but I already set the units to kN, m! Is there any way to change this? Also, regarding the placing of the doors/windows, is there any easy way to put them in desired location with pinpoint accuracy? Any help will greatly appreciated.
RE: doors and windows
As far as pinpointing accuracy, I'll usually view the opening in elevation and then use Edit>Align Points/Lines/Edges... to get things exactly where I want them.
Thanks for your reply, I've change the unit but still the dimension of the door opening is still in inches(see attached screenshot)
I thought you just wanted to input them as meters rather than inches, my mistake.
No, you're right ,I really wanted the dimension to appear in doors in meters(I'm using "reshape objects", the problem is, when I click the door openings in the model, the dimension that appeared is in inches[as you can see in the previous attached file], while I already change the units in kN-m in the lower right corner of the screen). Is there any way, I can change the dimension of the door to appear in "meters"?
