630 mm2 xlpe 36kv cable cost/km
Hello!
Does somebody know the cost/km for a 36kv 630mm2 xlpe cable?
RE: 630 mm2 xlpe 36kv cable cost/km
If the copper price it is now 8,270 $/tonne then 1km cable
is about 100,000 $.
Kinda vague question...
Single core or three-core? Do you want cost on the drum or cost installed? What location are you installing at? Is it ducted or buried, or on surface racking?
Thank you, Scotty for you remark .I forgot to mention.
It is the price of a km single core cable on a drum[wooden drum?].I think on
two drums as 500 m it is the standard delivery length [usually ] on a wooden drum.
By the way, I did not see any 3 cores cable of 630 sqr.mm.Did you?
Fair comment 7anoter4, a 3c/630 would be horrible to work with. wink
Over here MV cable doesn't generally get above 240mm² in multicore form. LV 3-core cables go up to 400mm², and that is awkward to terminate.
