Tappet Roller
Tappet Roller
Does anyone experiencing replace the roller assembly in tappet roller? is it possible ?
Regard,
Regard,
RE: Tappet Roller
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
RE: Tappet Roller
I have actually changed the roller assembly in a roller tappet assembly. The only real trick is that the bearing axle is usually held in place by swaging (if that is the correct term) the body of the follower. So after you drive out the axle you must find a way of reswaging or staking the body of the follower to securely locate the axle. I was working with Oz Ford SOHC straight six rollers and the correct parts were available from Ina. I have vague idea that a lot of roller followers are special sizes and probably not easily available.
RE: Tappet Roller
Does it affect the life time?
Kusuma
