Journal and view triad?
Hi.
Is it possible to switch on and off the view triad by journal?
Thanks in advance
Thanks in advance
kukelyk
RE: Journal and view triad?
CODE --> c#
using System; using NXOpen; public class ViewTriadHideNShow { public static void Main(string[] args) { Session theSession = Session.GetSession(); UI theUI = UI.GetUI(); NXOpen.Preferences.SessionPreferences sesPrefs = theSession.Preferences; sesPrefs.ScreenVisualization.TriadVisibility = 0; theUI.NXMessageBox.Show("Triad", NXMessageBox.DialogType.Information, "Turned Off now"); sesPrefs.ScreenVisualization.TriadVisibility = 1; } public static int GetUnloadOption(string dummy) { return (int)Session.LibraryUnloadOption.Immediately; } }Suresh
www.technisites.com.au
Can I run it from journal?
kukelyk
Suresh
kukelyk
