EN 1092-1 Bolt length
Does anyone knows where in EN1092-1 the minimum required bolt length is treated?
Or is bolt lengths discussed in construction codes that reference to EN1092-1?
RE: EN 1092-1 Bolt length
Simple google serch revealed following links; these may be useful!
http://mdmetric.com/tech/1092summ.htm
http://www.google.com.pk/search?q=EN1092-1&hl=...
http://www.steel-flange.com/CAFE71B3-FDEE-4D19-9C5...
http://www.samson.de/pdf_en/t00020en.pdf
http://www.hsflanges.com/En1092-1_type01_plate_fla...
http://www.hsflanges.com/En1092-1_type11_wn_flange...
http://www.vhg-group.com/en/welding-neck-flange-en...
http://www.vhg-group.com/en/welding-ring-en-1092-1...
http://www.vhg-group.com/en/lapped-collar-en-1092-...
or else search via Google yourself with the code reference 'EN1092-1'
Hopefully this proves useful for you cause resolution!
Best Regards
Qalander(Chem)
Perhaps EN1092-1 doesnt specify anything on that, which makes the answer a simple 'No'.
Perhaps a construction code referencing to EN1092-1 specifies bolt lentghs?
Perhaps a construction code like EN 13445 (vessels) or EN 13480 (piping) will mention it.
I'll check EN 13480.
