Reuse libraries installed (native), can not access them in NX75
After reading several posts about the Siemens libraries I downloaded and installed them.
(6 libraries ANSI Metric /Inch, DIN, SAE, UNI, ISO)
But I can not access them in the NX Resource bar or by the menu Tools.
The install.syslog indicated no problem.
I was wondering that I didn't have to change any settings in any DAT-files?
But "the user guide on installing reuse library for native mode_v2.2.doc" says nothing about that.
I am on NX7554 on XP 32 bit.
Other question can you install these libraries on W7 64 bit?
With kind regards,
Olaf
RE: Reuse libraries installed (native), can not access them in NX75
have you populated the install folder in the customer defaults?
Custommer defaults -> Gateway -> Reuselibrary -> General * NX native?
Of course you also downloaded and read the 'Machinery-Library-readme.doc' as well as using the install tools found in the 'Machinery-library-install-tool-2010-05-07.zip' file, corrert?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
To uwam2ie,
That was the info I needed, after adding : Libraries|C:/Program Files/UGS/Machinery Library to the customer defaults I could find them.
To John,
In the 'Machinery-Library-readme.doc' is nothing about the defaults.
With kind regards,
Olaf
