We have received with Blind Flange
We have received with Blind Flange with Rx 73 groove whereas requested for Blind Flange with R 73 groove. What is the difference between two?
RE: We have received with Blind Flange
What did the supplier tell you when you asked him this question?
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
It's probably a slightly different shape designed to force a more positive seal as pressure increases. More than likely R and Rx are interchangable. Now you can call them and verify what I just told you.
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
Thanks BigInch for your input.
I have got the same response above from supplier that both are identical. But, I would like to know which one used for better postive sealing. Can we use R 73 gaskets on RX groove??
I do believe so. Each should be interchangable with the other.
The "X" version is (supposedly) the better seal.
Both R and RX grooves have typical dims. The height of an R-73 gasket is 0.69", RX 1.250". Using an RX gasket will increase the standoff between the two flanges, which will also increase the OAL length of your assembly. The studs/bolts used to connect the flanges will increase using RX verse R gaskets. RX gasket provides a pressure-energized self-sealing effect.
Petrotrim Services
www.petrotrim.com
