WELD A COUPLING ACCORDING TYPE B FIGURE 5-8 FROM API650
Hi all,
I have to attach a new fitting in a existing tank. The fitting type is a coupling 1" 3000#.
The thickness of the shell is greater than 10 mm, so i'm not sure if i can weld the new fitting according the type b of figure 5-8 from API 650. In this sketch, API indicated a nozzle with flange.
Thanks for advance,
Thanks for advance,
RE: WELD A COUPLING ACCORDING TYPE B FIGURE 5-8 FROM API650
