Reference Geometry on the face of a drawing...
So here is the situation, I have an flex hose installation drawing that feeds an assy. This assy also contains another installation that installs the components the flex hoses attach to. So here is my perdiciment. I need to be able to show reference structure in the tube drawing without creating children in the product that are called out in the other installation drawing. Any suggestions? FYI, I am working in TeamCenter. If I was working solely in Catia, I would just pull in the necessary reference structure, mark it "do not show in BOM" in the properties menu and move on. But that doesn't seem to work in TeamCenter. The TeamCenter BOM creates a double dip for the parts I need to show as reference.
Hope this makes sense...
Medicman
RE: Reference Geometry on the face of a drawing...
Medicman
Medicman
This way teamcentre will not recognise the component , also it can be deactivated in the tree when you have finished the drawing so that you don,t get multiple instances in the DMU. We also put master lines and standard parts within components, we don't deactivate the standard parts component though.
If you need to update the views you will need to activate the ref structure component before update.
If that makes sense let me know as we are currently moving to team centre and we have built our products this way.
Hope that helps
Medicman
