motor connection
motor connection
motor connection
I need a diagram for a single phase, 240 volt, cap start motor.  Motor uses an internal start/run relay.  This is from a sears, direct drive table saw.
RE: motor connection
Suggestions:
1. Contact the motor manufacturer. Normally, the schematic diagram is inside the motor terminal box.
2. Baldor motor literature provides schematics for various Baldor single phase motors. The Baldor tech support could give you a hint regarding a corresponding motor substitute including the needed schematics.
