particle injection NX 8
Hello
I'm trying to use particle injection in NX8.0.
I have defined my internal volume with a fluid mesh, an inlet and an opening. Now I used the particle injection command on the same surface as where I defined the inlet flow.
But the status remains inactice of the particle injection, under simulation objects.
I've followed the steps to use particle injection that you can find under help.
Can anyone help me out?
Kind regards
RE: particle injection NX 8
wait for nx8.5 has the basic function of moldex inside nx when you have a mold license.
