format a string in drawing
I have string on a drawing controlled from an attribute and want to hide the last six characters from display.(nx8). Any format controlling available?
regards
regards
RE: format a string in drawing
In the expressions I have:
Kg_weight = (MakeNumber(ug_askPartAttrValue("weight (kg)")))
Then the applied attribute is: "Insert Annotation-->Note", Relationships, "Insert Expression"
<X0.2@Kg_weight> Kg
This takes the weight of 44.7849000000000 and shows 44.78 Kg on the drawing
yes and no my text attribute is a combination from date and time. I want to get rid of the time portion of the string
CODE
This will return the DateTime string variable, minus the last 6 characters. Use this new expression for your note.
www.nxjournaling.com
maybe a way to do it, are there no formating tricks from the note editor?
http://www.eng-tips.com/viewthread.cfm?qid=228567
