Discrepancy Between U-1A and U-2A Forms
We recently received a job for a Fitness for Service on a Vessel. I was going through the U-1A and U-2A forms and noticed that the minimum head thickness was different between the two forms. The minimum head thickness was lower on the U-1A form than the U-2A form. My original thought was to use the smaller of the two thicknesses since this would be more conservative. I've been searching through ASME Section VIII Division 1 code trying to find anything stating if I should use one or the other or what is acceptable, but I haven't been able to find anything. Has anyone else ran across this when doing a Fitness for Service?
RE: Discrepancy Between U-1A and U-2A Forms
I'd write the U-2A off to a typo or maybe missed the corrosion allowance, or who knows.
