Streamline curve between two curves in plane
I'm a CNC programmer with average modeling skills and I need to create middle curve/curves between other two simple curves/splines. My wish is this curve to be like streamlined toolpath not variable offset.
P.S.Excuse my poor English
Thank you
RE: Streamline curve between two curves in plane
The old trick is to create a surface ( thru curves or Ruled surface) between the curves(make sure it's not a planar surface) and then create an isoparametric curve in that surface.
Tomas
Thank you for the idea, Tomas,
but it doesn't do what I want.
..you can project your curve, to the plane..
kukelyk
Prelude, can you provide us an example, image or part, that shows what you have/ want ?
( If the surface becomes a planar or other analytic shape, its "U and V" directions doesn't follow the input curves, rather the X and Y axis
You can control this via Preferences - Modeling - Freeform - Freeform Construction result = B- Surface. = Force the output surface to become B-Surface math.)
Tomas
You are great ! That's what I'm talking about !!
Thanks !
P.S. Kukelyk, I didn't succeed open your file because I'm working on NX7.5, but you helped me !
Best regards!
