VFD as a LED light dimmer
Hello All,
Does anyone has any experience using a VFD as a light dimmer? I am a recent graduate and I have just started working at this company not too long ago, my boss wants me to take a ATV12H018M2 (240V Single Phase) and use it as a dimmer. I know there are triac, sine and IGBT dimmers out there in the market but they seem to be either incompatible or expensive.
Anyhow, I have read the manual and since it is meant to be for a motor I don't understand what configuration menu to use for my purpose. I have so many questions. Firstly, I would like to know about the drive outputs u,v,w and GND. How do I connect a 3 wire lamp to these outputs? U-Hot, V or W-Neutral and GND - Ground wire?
Secondly, if I connect drive output to a oscilloscope would I be able to see a PWM signal? I have so many more but I want to start with these two first. I think what he would like me to do is control when it fires or crosses zero. I'm so clueless and the manual seems to be not so helpful either. I would really appreciate if someone could guide me through this. Attached please find the user manual for the VFD I have been using.
GoldenEagle
GoldenEagle
RE: VFD as a LED light dimmer
I think this is a similar situation. One thing you shall NEVER try is to connect GND to the VFD output. N is OK, but not the GND.
Make sure you understand the specs for the LED first. Is it one single led? Or a string of LEDs? Is there any driver involved? Or series resistors?
Then read up on VFDs. They are all PWM these days. Connect between U and V (or W) you will probably fry something when doing so. Then find out why it didn't work. After adding a full bridge rectifier, some resistors and capacitors, you may have something that blinks - or burns.
You should chose scalar control, aka U/f.
Varying the frequency and thus the output RMS voltage, you will notice that the LED's output varies between dark and bright at double the set frequency. If that is what your boss wants, then show him that result. If it isn't (which I think) then tell him that it will not work. And explain why.
Gunnar Englund
www.gke.org
So here's what you are left with. You CAN use it, but only if the lighting is Line-to-Line powered. I would also be VERY hesitant to connect it to anything other than incandescent lighting, or rather nothing that has a ballast. Unlike a PWM UPS, the output of a VFD is not at all filtered (for the most part) so it may damage another SMPS or magnetic ballast by over heating it with the harmonic rich output. By the time you got done buying the appropriate filters, you would likely have spent less using a device designed for this purpose.
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Skogsgurra, I thought I would give it a try and tell him that it won't work too. But, when I talked to my colleagues(30+ years experience) they said they did this last spring and were able to control the brightness of the lamp using the same VFD I have with me now. They did by using the controls and codes from the user manual but they have not recorded the procedure anywhere. So, I have no choice but to say him that I don't understand how to use the terms, codes and configurations on the manual for our setup. We do use full bridge rectifier and current sink (transistors and resistors) as the lamp driver.
jraef, yes I live in NA and I'll keep that in mind. Thank you. As in the harmonic output, I was under impression that there is stage (DC bus/link) just for filtering in a VFD.
Now, it sounds like this lamp is 120VAC, so you could use a 240:120 transformer and this would filter most of the PWM signal out of the waveform on the secondary side. You can also ground one of the transformer secondary terminals and call it the new neutral.
If you factory reset the drive it would likely work as programmed. Set the motor voltage to 120V if you direct connect the lamp. Give a start command and see what happens. Wear the proper PPE.
Given tha above statement, I see your point. His boss may just be giving him a "what if" sceanrio.
Let us know how it turns out, preferably with pictures of the fireworks.
Take precautions...
Around 200V AC i/p was applied to a VFD to get 120V o/p(across a L and GND).
The moment I apply voltage to a non-running VFD it generates a surge output and this surge is enough to a flick a lamp.
When the lamp was powered through a VFD, I have tried changing the frequency using a jog dial on a VFD. I was able to see change in pulse width on oscilloscope but I have not seen any change in the brightness of the lamp. And the last but most annoying part was when the VFD was running, a buzz sound was heard from a lamp, the buzzing sound changes with the change in frequency and stops when I stop the VFD. I think the buzzing has to do with the 8KHz output of a VFD.
Sorry Jeff, no fireworks hence no pictures.
Told you so.
Gunnar Englund
www.gke.org
Keith Cress
Gunnar Englund
www.gke.org
I strongly suspect that if you vary the input voltage, specifically lowering it to dim the array, the poor power supply will do its very best to maintain the nominal output of the LED's until it either shuts down or dies trying.
It might be interesting to try. I'd think I want to get a lot of instrumentation around to see what happens to voltages and currents and input and output waveforms.
old field guy
I don't get why changing the frequency is not changing the RMS output am I doing something wrong?
May I know what is a scalar control U/f you have mentioned above? Is it a kind of VFD with that control?
If you want to effect the RMS you need to adjust the programmed power/hp that the drive is set for.
Keith Cress
Gunnar Englund
www.gke.org
In the meantime, make sure you understand the difference between RMS voltage, fundamental component and total voltage (including all harmonics). With a good multimeter, you will read all components in the output voltage while the voltage you set via the input setpoint is RMS of fundamental voltage.
And don't forget that it is between lines on the output of the VFD that you shall measure. Not fom line to GND. That was described in an earlier post.
Finally, not so sure that your LED reacts to RMS. Could just as well be AVG. Also, if your LED "ballast" is anything else than a resistor, you may be in for some surprises.
Gunnar Englund
www.gke.org
goldeneagle272 What exactly are you using for "lights"? Got a link?
Keith Cress
As soon as it starts it will turn on a pair of transistors to apply the full capacitor directly across the load.
For the brief instant in time while the transistors are on I would expect the LED to be very bright.
One way of making LEDs more appear brighter to the human eye is to pulse them at high power/high frequency, the eye is fooled into seeing it as though it was on all the time just as the image on a TV appears to be there when in fact its flickering off and on.
Another example is a movie screen for the split second while one picture is changed for the next the screen is blacked right out by the rotating shutter, your eye can't see that but will notice wheels that appear to rotate backwards.
I thing the numbers in a calculator (I'm talking about the old LED or discharge tube displays) are also flashed in sequence too fast for your eye to see.
I cannot share more about it since this technology is patent pending, all we use is a current sink (MOSFET and sense resistor) to control each LED stage. LED stage consists of number of LEDs depending up on our requirement, voltage drop and i/p voltage.
As in the frequency control I mentioned above it was just by using the jog dial, with the set output frequency 2kHz - 8kHz.
I was able to control the brightness a little, flickering at low frequency (again jog dial) to constant brightness at high frequency. But, with the restricted range (jog dial)I wasn't able to fully turn up the brightness, I used both 120V and 230V lamps.
This is an excerpt from the manual about the jog dial, "the jog dial on the HMI acts as a potentiometer to change the reference value up and down within the limits preset by other parameters (LSP or HSP)." LSP being low speed set at 0Hz and HSP high speed set at 400Hz(max). The adjustment range for a jog dial is 0-100%.
The VFD output is a variable frequency and voltage going from zero Hz up to a few hundred Hz. Just as your excerpt says.
It is fine that your lamp is "compatible" with 60 Hz. Good, good. Sarcasm.
Gunnar Englund
www.gke.org
I'm still puzzled why you would want to use a VFD to
control LED brightness though.
If you set the VFD for a motor rated frequency of 60Hz with a motor voltage of 240V then the pot should vary the PWM generated V/Hz output from 0V/0Hz to 240V/60Hz.
http://www.gke.org/pub/files/VFD%20as%20a%20LED%20...
Gunnar Englund
www.gke.org
What do they teach in engineering schools these days? You're doing it all backwards. The first step of this experiment is to investigate the LED SMPS to determine how it will you can dim the lamp. If you can dim the lamp, ou then have to determine if the VFD output will give the SMPS what it wants to be able to dim the lamp. If it's not compatible then determine if there is a way to make it compatible.
You have to learn to read too. The first 2 posts told you to connect between phases on the output of the VFD and that connecting to a SMPS was a dumb thing to do.
Bill
"Why not the best?"
Jimmy Carter
I already posted what should work as the solution.
