Repair of Car Rims
Repair of Car Rims
With vintage cars early 70's having wobbling rims during dynamic balancing, can these rims be straighten out since new rims would no longer be in production
RE: Repair of Car Rims
... but there are people who repair rims for a living,
and have stayed in business doing it.
First check that bearings are okay, and hub seating surfaces are clean.
Second check hub face runout with a dial indicator.
Then start checking the rims.
Mike Halloran
Pembroke Pines, FL, USA
Was the purpose of the balancing to correct a vibration problem?
I got a set of JCPenney tires that really couldn't be balanced properly, because they were 1/2" out of round. The outsides were fuzzy when spun on the dynamic balancer.
Damn POS tires wore like iron, beat the crap out of the car.
Mike Halloran
Cheers
Greg Locock
While 14" rims are available, none would fit the hub caps, so the question remains can these rims be restored to proper tolerance? The mechanic said it could not be done and I am the type of a guy that does not give up until there is certainty.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Wobbling wheels would not cause side drift.
Cheers
Greg Locock
sounds like steel wheels to me.
If neither I nor my pickiest passenger notice any vibration in the steering wheel, seats, or rear view mirror around 15 hertz when driving any speed between 40 and 80 mph then I think the wheel/tire runout and balancing are good enough.
The runout that is "visible" is undependable and hard to quantify. I think tire machines that (commendably) measure runout do so with roller pushing against the tire tread, so it is related to tire stiffness, not just the geometry of the unladen tire.
Not that Olde Volvos are luxuriously smooth highway runners, but one of the pocket "green books" has this:
Volvo 240 - max runout measured at the tire bead seat area (accessible only with tire removed)
steel wheels .032" radial 0.04" axial
alloy wheels .024" - 0.032"
i'd be more concerned with the tire tread runout, which is the sum of the wheel and tire runouts and how they are indexed relative to one another.
I think in the 70's Chrysler said 3/32 inch (about 0.09 inch) was the tread runout limit for police cars intended for high speed pursuit. Back then finding tires with assembled runout of 1/8 inch was pretty common. the few tires I've played with in recent years have impressed me with the much improved accuracy of manufacturing.
i think the 'side drift" that the mechanic referred to was a "waddling" motion/ sensation at low speed. An extreme but unmistakable example is the waddle that results when a radial tire's belt separates. An inspection of the tire generally reveals a HIGHLY visible "wow" in the tread runout.
https://groups.google.com/forum/?hl=en&fromgro...
Pat
for site rules
