loop for SolverAdd
loop for SolverAdd
loop for SolverAdd
I need a Loop for SolverAdd.. Is it possible?
I tried this:
Dim h As Integer 'Número de restrições
Dim w As Integer 'Referência para o Loop
Dim q As String 'Referência para localizar célula que deve ser lida
h = Plan1.Range("T8") - 1
q = 7 + Range("E2")
For w = 1 To h
SolverAdd CellRef:="$I$" & q, Relation:="$I$" & q + 1, FormulaText:="$I$" & q + 2
q = q + 5 + Range("E2")
Next w
But this is a incompatible type.
Please help me.
RE: loop for SolverAdd
thanks dude..
just missed it:
Dim Reltn as long
Reltn = RAnge("$I$" & q + 1).value
For w = 1 To h
SolverAdd CellRef:="$I$" & q, Relation:="" & Reltn, FormulaText:="$I$" & q + 2
really thanks
now.. I have a problem with SolverOk
Dim n As Integer ' Procura a última linha preenchida das variáveis
n = Plan1.Range("B65000").End(xlUp).Row
'Seta os parâmetros iniciais
SolverOk SetCell:=Range("$E$5").Value, MaxMinVal:=Range("$T$4").Value, ValueOf:=0, ByChange:=Range("$E$8:$E$" & n).Value, _
Engine:=2, EngineDesc:="Simplex LP"
There is no error. But nothing happens.
It just show the restrictions in the windows of Solver.
I think you need to call SolverSolve after you have called SolverOK.
Yes.. i did
Look the complete comand:
Sub Solver()
Dim n As Integer 'Last line
SolverOk SetCell:="$E$5", MaxMinVal:="$T$4", ValueOf:=0, ByChange:="$E$8:$E$" & n, _
Dim R As Long
q = 7 + Plan1.Range("E2")
For w = 1 To h
R = Range("$I$" & q + 1).Value
SolverAdd CellRef:="$I$" & q, Relation:="" & R, FormulaText:="$I$" & q + 2
q = q + 5 + Plan1.Range("E2")
Next w
SolverSolve True
SolverFinish KeepFinal:=1, ReportArray:=1, OutlineReports:=1
End Sub
I copied and pasted that code, and made some minor modifications to work on a simple problem (solving a quadratic equation), and it worked without any problem.
For what it's worth, here is the code I actually used:
Sub Solver()
SolverOk SetCell:="$B$5", MaxMinVal:="$B$9", ValueOf:=0, ByChange:="$b$" & 5, _
Engine:=1, EngineDesc:="GRG Nonlinear"
Dim R As Long
h = Range("B10") - 1
q = 7 + Range("B11")
For w = 1 To h
R = (Range("$B$" & q).Value - 3)
SolverAdd CellRef:="$B$" & q, Relation:="" & R, FormulaText:="$B$" & q + 2
q = q + 5 ' + Range("E2")
Next w
SolverSolve True
End Sub
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
So strange.
I realized the solver parameters are only filled restrictions when I run it.. the other parameters are blank.
Is it possible that some reference is not checked?
What version of Excel are you using? (I'm using 2010).
Is it possible to post your spreadsheet?
Doug Jenkins
Me too.
spreadsheet:
http://sdrv.ms/QO8wLA
It's just a prototype.
I'll improve it.
I'm Brazilian, so the spreadsheet is in portuguese.. ^^
This seems to work:
Dim ChangeAddr As String, MaxMinVal As Long
ChangeAddr = "$E$8:$E$" & n
MaxMinVal = Range("T4").Value
SolverOk SetCell:="$E$5", MaxMinVal:="" & MaxMinVal, ValueOf:=0, ByChange:="" & ChangeAddr, _
It seems that if we want to define anything with a string formula we have to create a variable, then use :="" & VariableName
I don't know if that is the only or the best way to do it, but it seems to work.
Doug Jenkins
Really thanks.
You are the man.
I had already tried something like this .. but I must have written something wrong.
Thank you so much.
