run a journal with the special command
Hi , I have tried to run af journal (VB) by using the environment variable USER_RETRIEVE= (open part),
and the enviroment variable USER_FILE= (save part).
(The value for the variables is the entire path to the journal(*.vb))
But I get the message "Failed to load image - see log file for details".
If I use a grip-program (*.grx) , there is no problem to run it .
Maybe someone here on the board know, if it should be possible to run *.vb or *.dll executable´s from the
USER_RETRIEVE or USER_FILE variables ?
lklo
lklo
RE: run a journal with the special command
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
