Right turn steering lead on crown roads
I am fimilar with rack and pinion steeing, but not the fine points of suspension components.
A perfectly balanced and symmetrical steering gear wants to drift to right turn on a crowned road.
What in other suspension components could I look into to prevent this?
RE: Right turn steering lead on crown roads
If you must, a slight change in castor will pull to one side. I forget which way you do it.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
You could use cross camber, I suppose.
Incidentally your vehicle will almost certainly have come with tires that generate a sidepull in their own right (conicity and plysteer).
Cheers
Greg Locock
