Revision Cloud command?
Is there a command in Draftsight to draw revision clouds? I been searching around and can't find any info.
Thanks.
RE: Revision Cloud command?
It was added in the latest release version 1r3. Type cloud at the command line. It didn't show up in the draw menu (64 bit version.) That said, when it created the cloud the ends of the arc overlap - looks sloppy. I don't remember them working this way in Acad from many years ago.
