Problem with dc motor
Hello.
I am trying to put a small dc motor working and regulate speed with PWM generated by arduino. The transistor i am using is a bc547c.
The problem is that the motor make a strange noise but doesn t spin (no its not damaged). Connected an amp to see the colector current and it increases as i increase duty cycle, but the voltage between colector and emiter stays more or less the same. Shouldn t that decrease as current increase? There is no voltage across the motor as it stays in the transistor.
Motor is a mabuchi from a car toy;
As external motor source i used 4 1,5 V batteries;
I calculated resistor base to have enough current to feed the motor according to transistor and motor datasheets.
Do you have any idea for wath is happening?
Thanks.
PS: Atached are the schematic hand made and a picture of the circuit.
Thanks.
RE: Problem with dc motor
A MOSFET is a better choice of switch than a BJT at low voltage, and easier to drive unless you're running at very high frequency.
You need a freewheel diode across the load, otherwise you will destroy the transistor.
Buy a book on the fundamentals of power electronics.
From what i understood of your reply the base current is not enough?
I based my calculations on the atached datasheet. Could u have a look and tell me if 0,5 mA in base is not enough for saturation?
I don t know the meaning of "freewhel" but i have a 1N4007 diode across the motor, i just forgot to draw on the schematic.
The PWM frequency is 430 Hz.
I based this project on another person's, he uses a 2n222 NPN and it works great.
Thanks again. Have to buy on book of these.
I will try to lower resistance in base to 1 K.
Thanks.
I put a 1K pot in base and moved it to lower resistance till the motor spin. Voltage source was 6 volts, the same as colector.
The motor decreases speed till the max pot value that corresponds to more or less 4,7 mA in base, VCE is around 2,6 V and Icolector is around 170 mA. I have one more litle problem, sometimes the motor doesn t start when the pot is at its max resistance, and i have to lower ir for the motor to start spining. Could this be connection problems or is this normal?
Thnaks to everyone.
PS: Tomorrow will try with PWM from arduino.
That same problem is why a lot of house fans and ceiling fans that are multi-speed, always have the highest speed immediately adjacent to OFF. This means the fan will always be jerked into motion.
Keith Cress
By the way, allready tried with arduino and it works ok.
Next task is connect a tooted ring to motor axle and read rpm with a inductive sensor. Lets see if i can do this.
Thanks guys.
