WHEN CREATING A NEW MATERIAL HOW CAN YOU USE THE USER DEFINED PARAMETERS IN YOUR RELATIONS
i have created a new material and inside this material there is a user defined section you can add parameters. is there a way to pull these user defined parameters into the relations?
RE: WHEN CREATING A NEW MATERIAL HOW CAN YOU USE THE USER DEFINED PARAMETERS IN YOUR RELATIONS
This should work, where PARAMETER is your user-defined parameter and MATERIAL is the name of your material.
material_param("PARAMETER","MATERIAL")
It does work for the built-in parameters.
worked great thanks
