UBC / IBC Earthquake load level
Hi, Is the Earthquake load that is produce, by using the methods as set in the UBC/IBC, in strength level or service level? Where does it state in the UBC/IBC code that the Earthquake load that is produce is in such a level? because i cant find it.
It is also interesting HOW and WHY did they come up with strength level load for earthquakes. (if the EQ loads produced by UBC/IBC is at strength level)
RE: UBC / IBC Earthquake load level
