pressure testing a blind flange
what is the procedure for pressure testing a blind flange???
RE: pressure testing a blind flange
Not required under most Codes. Are you sure you are required to do this?
If you NEED to, make a piece of pipe with a flange that matches your blind. Assemble, fill w/water, hydro.
Done right, you could test 2, 3, or 4 at once...
thanks dude..its 2 certify 4 inspection...i had d same idea..
