Parallel (Vs) Series Chillers & Pumping Arrangement
neutralDear HVAC Folksmedal
Which system arrangement is good. I want to know between which one should be selectd based on what criteria?. I would appreciate if its limitions, advantages and disadvantages is discussed as well.
H-VAC
RE: Parallel (Vs) Series Chillers & Pumping Arrangement
Wrong forum. This question should be in HVAC. Check out ASHRAE handbooks first.
