Transformer connections and load sharing
We need a 30W,24v for a toilet device.We have a 240V supply in Qatar.But
our supplier who is in US has send us 2nos of RATING 120V/24V 50VA.
Is there any way by interconnections I can make it 240V/24v.
thanks in advance
Abraham
thanks in advance
Abraham
RE: Transformer connections and load sharing
Bill
"Why not the best?"
Jimmy Carter
Are you sure? What about amp-turn balance in the transformers? The unloaded transformer will behave as a reactor.
Bill's solution would work if the transformers are matched.
Well...After reading your comment, I am not sure. That being the case, I withdraw my solution. Thanks for stepping in.
I do agree that Waross offers a good solution. With matching transformers and proper polarities, this should work well.
Amp turns balance says it all. Thanks Scotty.
Bill
"Why not the best?"
Jimmy Carter
Bill
"Why not the best?"
Jimmy Carter
Bill
"Why not the best?"
Jimmy Carter
75va & 500va xmfrs, 240/460 pri->120v sec. Wire 120v across both H1-H3 (240v)(ignored H2&H4) pri in series, no load produced:
Vpri Xfmr NL sec comments
83 .......75va .... 43v....68 ohm....Rpri (I did not measure I or L or calculate Z)
38 .... 500va .... 19v.... 5 ohm ....Rpri (I did not measure I or L or calculate Z)
Put 60watt bulb across 75va xfmr for 15va load:
3 ......... 75va .... 0.5v
120 .... 500va .... 61v
Tied sec in parallel (phased properly):
60 ....... 75va .... 30v
60 .... 500va .... 30v
secondary recirculating current: 0.8ma
It also makes sense that I got the full 60v across the lite in series with the secondaries wired out of phase.
Thanks for the feed back.
Bill
"Why not the best?"
Jimmy Carter
