Assembly load options-from search folder method
As understood, assembly load option-from search folders will load the parts from that particular folder. Is there any way to search the sub folders also by just one entry.
I mean, I have given search directory called std_parts and it contains lot of sub folders(hasco,dme etc). But nx search only in std_parts and not in its sub folders.
AK
NX 7.5.5.4
RE: Assembly load options-from search folder method
Got the answer. Folder path...
thanks very much
AK
NX 7.5.5.4
