PUSHOVER ANALYSIS by STATC GENERAL (URGENT)
Hi, I am currently running a pushover analysis with different axial load apply on the structure with a constant displacement of 65 mm. I have getting same error such as too many attempt made for this increment and time increment is less than minimum specified. I have search for solution for the past few weeks including this forum yet my problem still not yet solve as I am new to ABAQUS. I know the issue is happen to the control parameter of the static general as I have try few axial load with successful but the analysis will failed when I increase my axial load. I have try to add stabilizer to the analysis but the result is not what I expected. Therefore, is it any way I able to understand the control parameters of the time increment thingy ?
Thank you and appreciate.
