machining operatins broken down to different files?
So there is a part.starts as a casting, there are up to 17 different operations possible for this casting, Superior would like to have all linked ..so for example file 123x678 adds a bore, drawing 123x567 adds a cavity for a shock valve, drawing 123x9546 adds the threaded holes on top,,,each model shows casting with one machining operation, final part number will show a casting with a bom with each of the model files of machining operations shown. The boss would like this to be parametric so if one of the machining operations are changed that would reflect downstream and I am kinda at a loss on the best , most efficent way to make this happen
