- AISI code check not calculated -
Risa Error:
Anyone?
Anyone?
RE: - AISI code check not calculated -
It could be a shape that the program doesn't yet know how to do code checks on. The help file should give more details about that.
I'm not overly concerned because they not really structural members (as stupid as that sounds).
What version of the program are you running? At one point, this error would occur when any minor weak axis moment put the web into compression. But, I thought we (RISA) had added some tolerance which bypassed this check for low levels of applied weak axis moment. I could be wrong about that, though. My memory on the issue isn't very clear. If you posted your model, I could tell for sure.
