error when performing non-linear analysis on a metallic foam
I am doing a Non-linear solving on a metallic foam on ANSYS, but I am having problems with volume meshing. many elements have shape warning limits when meshing, and when solving, after the 3rd iteration, ANSYS always give an error message saying the elements are highly distorted. I am using solid 45 to mesh volumes. Tried meshing by element lenght, element divisions, and smartsizing. The warning always appear on meshing, and the error always appears during the 3ª iteration.I´m tring to find a way to mesh without element shape warnings
Can anyone help?
regards,
Hugo
RE: error when performing non-linear analysis on a metallic foam
There may be an issue with the geometry so this needs to be checked. Does it have to be meshed with 45s? Can tets be used?
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
Tets are the only way to mesh. Quadrilaterals give an error when trying to mesh. I get shape limit warning on nearly 100 elements. I think this might be the cause. How can I avoid shape limit warnings?
