Simple DraftSight Script & close command
Hello Everybody,
My problem is quite similar to http://www.eng-tips.com/viewthread.cfm?qid=315908#... (closed thread, no answer given)
I'm trying to run a DraftSight script (with prompt commands, no API), with a batch command (on several files). It should save a DXF file as a DWG file.
The script stops when I use the close command, so I'm not able to do my batch when I close the first file.
This script won't work until the end :
CODE --> script
Open c:\TEST1.dxf
SaveAs Open c:\TEST1.dwg
Close
Open c:\TEST2.dxf
SaveAs Open c:\TEST2.dwg
Close
This script will stop after the 1st close command, and won't go further.
Any idea why ?
I Also tried this without success :
CODE --> script
Open c:\TEST1.dxf
Open c:\TEST2.dxf
Close
Close
But DraftSight will only Save As DWG the first DXF (TEST1) two times, and won't bother taking care of TEST2, even if it's displayed on the screen at the end of the script.
Any hint would be appreciate, thanks in advance.
PS : I'm new there, if there is a section where I should introduce myself, please let me know.
RE: Simple DraftSight Script & close command
I'm sorry, I did a mistake, it's not not
but
SaveAs c:\TEST1.dwg
So here is the correct script :
CODE --> Script
Open c:\TEST1.dxf
SaveAs c:\TEST1.dwg
Close
Open c:\TEST2.dxf
SaveAs c:\TEST2.dwg
Close
And the second also corrected :
CODE --> Script
Open c:\TEST1.dxf
SaveAs c:\TEST1.dwg
Open c:\TEST2.dxf
SaveAs c:\TEST2.dwg
Close
Close
Maybe it wasn't clear, but the "corrects" scripts of my second message don't work neither.
If someone succeed in runing script on several file in DraftSight, please let me know.
