ETABS DESIGN MOMENT
ETABS DESIGN MOMENT
Im a newbie in etabs, i have some clarification regarding the design moment used by etabs in designing the beams, when I open the
envelope data, its shows 2 moment in a section (support location), moment for top and moment for bottom. This 2 moments from different
load combination. From what I learn in designing manually we use only one design moment for designing the beam in that section, and also
1 load combination? can someone explain why there are 2 moments in the evenlope for that section. Thank you.
RE: ETABS DESIGN MOMENT
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
chris magadia
www.chrismagadia.com
ChrisMagadia.Com - The Structural Engineers' Forum and Resources Website. Civilizations owe its existence to Structural Engineering. Do you Agree?
