Worthington Pump
Worthington Pump
Worthington Pump
We have a Worthington Pump, Model: 0820, Serial: Y650869 1.5 x 2.5 x 6
I am trying to determine the max flow rate and have been unable to locate any information or curve.
I have dropped a querry to Flowserve, but so far no response.
Any guidance would be appreciated.
Thanks in advance.
RE: Worthington Pump
What do you know? Do you know the maximum discharge pressure, it's rated head, pump speed, flange ratings and the power rating of the driver it is/was attached to?
It is possible to estimate capacity and head based on other parameters.
We might start with around 60-75 gpm.
Start typing.
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
Hi BigInch;
The pump is currently attached to a 7.5 HP, 3450 rpm 208/220 3ph Baldor motor.
I will see what what other info I can get off the pump in the AM.
Thanks TenPenny, just what I needed!
Not a problem, I try to keep old stuff around, i'm always looking for information on old pumps.
Thanks, that was much easier than I thought it was going to be.
